HP Forum Archive 20
My HP 15C LE has just arrived! Wow!
Message #1 Posted by Antonio Maschio (Italy) on 27 Jan 2012, 6:08 a.m.
My HP15C-LE is in my hands. All keys work perfectly, with a pleasent click (not equal to the vintage one I've got, but hey, that's it!) and it IS faster, wow!
I'm gonna use it as my everyday calculator, along with a vintage HP11C.
Long live the Voyager series!
-- Antonio
Edited: 28 Jan 2012, 6:04 a.m. after one or more responses were posted
Re: My HP 15C LE has just arrived! Wow!
Message #2 Posted by Jeff Johnson on 27 Jan 2012, 1:00 p.m.,
in response to message #1 by Antonio Maschio (Italy)
Enjoy! Gotta love having a new toy!
Message #3 Posted by Massimo Gnerucci (Italy) on 27 Jan 2012, 4:08 p.m.,
Also my unit was delivered today!
And a 12C AE, a 20B, a couple of 30B (one to be converted into WP34S) and other HP recent paraphernalia...
Let's enjoy a late Xmas! ;-)
Massimo
Message #4 Posted by bluesun08 on 27 Jan 2012, 6:09 p.m.,
I heard that on the HP 15c LE some keys can be faulty. Which keys are this?
Message #5 Posted by Paulo MO on 27 Jan 2012, 6:44 p.m.,
in response to message #4 by bluesun08
It might happen with any key (GSB, in my case, other keys in other cases). But that problem is hopefully taken care of, on the new batch. I don't think you need to worry at all, if you are buying one of the new european batch.
Paulo
Message #6 Posted by Lode on 27 Jan 2012, 7:20 p.m.,
in response to message #5 by Paulo MO
Is it normal that the "f" and "g" keys rattle when you shake it? They all press fine.
Message #7 Posted by Paulo MO on 27 Jan 2012, 7:47 p.m.,
in response to message #6 by Lode
Yes. Those two keys are mounted differently from the others, and that creates the rattling (even though, depending on the moulding sequence, some calculators rattle more than others). You'll be fine. It's a great calculator.
Best
Paulo
Message #8 Posted by Brandon Poindexter on 27 Jan 2012, 8:40 p.m.,
Mine rattle as well.
It's a shame that they couldn't get this worked out at first, as when I use it on a solid surface, the F and G keys buzz a little as I type around. Would HP count this as a defect I were to ask for a replacement???
Message #9 Posted by db (martinez, ca.) on 27 Jan 2012, 9:56 p.m.,
in response to message #8 by Brandon Poindexter
it's not a fault, or a deficiency. it doesn't cause problems. they'd probably laugh at you.
now the way it eats batteries; that's a defect.
Message #10 Posted by Bruce Zastera on 27 Jan 2012, 10:28 p.m.,
in response to message #9 by db (martinez, ca.)
Just how fast does it eat batteries?
Frankly, I wish they would actually bring back the HP15C rather than a cheap knockoff of their own product. If I just wanted the same functionality with a lousy keypad and rapidly depleting battery, I could use my iPhone. :)
Edited: 27 Jan 2012, 10:31 p.m.
Message #11 Posted by Antonio Maschio (Italy) on 28 Jan 2012, 6:10 a.m.,
Mine rattle as well, but I don't consider it a fault. It seems like they sound just as different keys, and they are indeed!
I experimented it a bit, and all worked well until now. Fast and well-responding.
I read about the mistakes in the manual, and they are all there!
HP, HP, two steps ahead and one backward! But I'm so happy for this little new beast that I can pass over it... ;-)
-- Antonio
Message #12 Posted by Massimo Gnerucci (Italy) on 28 Jan 2012, 8:18 a.m.,
in response to message #11 by Antonio Maschio (Italy)
Mine has no rattling keys at all. :)
Now to turn a 30b into a 34s... then back to my beloved 41CL, I presume.
Massimo
Message #13 Posted by Marcus von Cube, Germany on 28 Jan 2012, 8:56 a.m.,
in response to message #12 by Massimo Gnerucci (Italy)
I doubt the latter. ;-)
Message #14 Posted by Massimo Gnerucci (Italy) on 28 Jan 2012, 2:58 p.m.,
in response to message #13 by Marcus von Cube, Germany
Eheheheh Marcus... :)))
We'll see: right now I have to put together all the pieces needed for the setup, then I'll try a flashing session.
But a love affair 32 years long is hard to break, or so I feel now.
Greetings,
Massimo
Message #15 Posted by Massimo Gnerucci (Italy) on 29 Jan 2012, 3:11 p.m.,
I must thank everybody who provided guides, tools and how-to's on flashing new firmware on 20B/30B.
Everything went really smooth in about 15 minutes (checking each step 3 times), without using the preferred environment: Windows 7 64bit, Prolific USB-RS232 cable, your modified MySamba program and 2344 firmware release.
I now have a new lightweight, extremely fast, easy to handle, inexpensive, replaceable scientific calculator.
I only miss the overlay that seems to be necessary to use it.
Thank you all: it's an impressive achievement!
Massimo
Message #16 Posted by Marcus von Cube, Germany on 29 Jan 2012, 3:23 p.m.,
in response to message #15 by Massimo Gnerucci (Italy)
Eric's achievement with the overlay is priceless. Go for it!
Message #17 Posted by Massimo Gnerucci (Italy) on 29 Jan 2012, 3:27 p.m.,
in response to message #16 by Marcus von Cube, Germany
Just did it! ;-)
