Re: RedDot or no? Message #4 Posted by Lincoln R. on 26 Jan 2012, 10:13 a.m., in response to message #1 by Matthias Wehrli
Looks like a frankencalculator to me. Neither 1143A 00026 or 1143A 04426 (which might be a mistake since it's on the "property of" tag) seem like correct serial numbers for a version 4. I can't make out the serial number tag on the bottom of the machine in his picture.
If I had to take a guess I'd think this is a calculator that got repaired, possibly not by HP. Both of the legible serial numbers fall into the range that could be red dot models, although did the red dot calculators come from the factory with the sticker inside the battery compartment?
