Re: Voyager 1xC emulation in the same unit? Message #5 Posted by uhmgawa on 24 Jan 2012, 1:09 a.m., in response to message #4 by Jeff O.
I can see that what you would like to do would be an improvement over a simple port to a sam7 voyager if the hardware were available.
I believe I'd started down this slippery slope with a well
intentioned push from WalterB [appreciated] in the course of
discussing my KINOMI/NUT replacement project. Yet even if
one could scare up a display retrofit, there are interconnect
issues to resolve. And quite honestly the easiest way to
address this is with a new board layout which is a relatively
simple task. Well if we've got a new board layout it is
difficult to resist adding the sorely missing functionality in
that otherwise vacant PCB real estate. But wait, if we're
creating a replacement board there really isn't any compelling
reason to put an aged AT91SAM7L128 back into the design -- we
could do considerably better with a more recent SoC. And
having arrived at the foot of the slope, what are we really
repurposing besides an ABS enclosure in a unique form factor?
If we toss out that design constraint we no longer have the
severe display retrofit limitation.
I would of course encourage the simple port, because the hardware is available (in my hands, even.)
Admittedly a valid argument exists there as the hardware is
quite underutilized. Only about 25% of that 128KB flash is
actually needed to contain the 15c legacy firmware and a
NUT/Voyager emulator. Even the graphic voyager prototype
depicted above with KEMU core, all of 11/12/15/16c rom images,
multiple firmware support, serial console, graphic rendering,
several fonts, demo cruft, etc.. doesn't even cross over 64KB
on a C language challenged architecture. Add to this the idle
resources present in the
sam7 voyager
and it is difficult to resist improving upon the design.
But with the concern over the legality of using the original rom images or reproducing their functionality, I could not blame you if you did neither.
Well, there is certainly precedence for releasing an emulator
decoupled from its essential firmware. Yet doing so makes for
somewhat of a poorly scaling proposition where each user needs
to locate and program firmware images before a unit is functional.
