Re: HP-65/67 back label Message #4 Posted by Kees Bouw on 18 Jan 2012, 11:40 a.m., in response to message #3 by Dale Reed
Note the "Made in U.S.A." on the bottom line of the HP-65 label and the "Made in Singapore" on the conversion factors label.
If the serial number on the unit in question has an "A" after the first four digits, I would expect a label that says "Made in U.S.A. (the HP-65 label). If the serial number has an "S" after the first four digits, I would expect a label that says "Made in Singapore" (the conversion factors label).
Dale
The serial number has an S and the label says "Made in Singapore" so that matches. Also, there is no serial number etched between the top two feet as is common for the HP-67 (instead, it is on a label between the bottom two feet, just where it should be), so I must conclude that the bottom is genuine HP-65. The "Useful Conversion Factors" label is very even, no folds or wrinkles of any kind. So if someone replaced the back label they have done an extremely good job. If it has been replaced by a new fake label, then it makes no sense that the wrong label was used. They might as well have put on the "usual" label. It's a mystery.
