Re: tapping heat stakes Message #5 Posted by uhmgawa on 31 Dec 2011, 12:22 a.m., in response to message #3 by David Griffith
My reason for wanting to tap the heat stake stubs is because it makes subsequent disassembly easy. With the use of epoxy, that wouldn't be the case.
Yea I really wouldn't recommend using epoxy as suggested here as
it will bond far too well to the pcb and be a nightmare to remove
should you have cause to subsequently free the pcb. Actually
it probably isn't the best adhesive choice either for a number of
reasons.
The best method I've found to reseat ABS heat stakes is with
acetone. Acetone is an aggressive ABS solvent and spectacularly
volatile. As such it creates an excellent weld bond and flashes
off quite rapidly. The net effect is you can "glue" a new head
onto a stake post in about 30 seconds, during which the head
can be held under pressure to restore joint compression.
I've built a small ad-hoc jig
to apply pressure to the joint until the solvent dissipates but
a drill press quill with a weight on the quill lever works
as well.
A little acetone goes a long way and some experimentation on
scrap ABS might be a good ideal to get the feel for its
characteristics. One issue with pure acetone is its low
viscosity which can cause it to run away from the intended
target in this application. I thought to experiment by
dissolving some scrap ABS in acetone to create a more viscous
adhesive which should stay put far better, but have been doing
ok with straight acetone applied sparingly.
On that last note I'd recommend using a syringe with about a 30
gauge needle to apply the stuff to the stake posts as you wouldn't
want unintended ABS exposed to the solvent as I've alarmed
earlier.
