Unabashed CL user promotion or why the 41CL? Message #1 Posted by Geoff Quickfall on 19 Dec 2011, 2:44 p.m.
Hello all;
This is directed to anyone that knows the 41C family (CX) capabilities and draw backs.
________________________________________________________________
I have a CL (actually 2 now). On the way to Sydney, Australia (a 15 hour leg) on Thursday last week the display faded to non existance on the CL. No big deal as it was a cold solder joint on one of the LCD contacts and easily fixed today.
As a result I could not use the following routines:
Great Circle routine
- data base solutions
- coordinate solutions
Intermediate Latitude
Break scheduler with print functions (very important!)
World time clock
Alarm setting
Stopwatch setting
Temperature corrections
Assorted conversions
Fuel in Tank
Airport door codes (security encrypted)
Phone numbers (PDA)
Metric altitude conversion (data based)
I pulled out my 42S (32K version) and had to plod through with it ;-) It does contain the majority of programs listed but does not contain the convenient data bases which allow for Airport code prompts. I can only say, I could not wait to get home and fix the solder joint on the LCD as the 41CL was sorely missed, especially its ability to do dynamic time functions. The 42S is great but once bitten by the 41 and now the 41CL, I cannot go back
So now to the crux of this story. Basically, why the 41CL?
-the 41CL is fast, very fast, at least, for my programs,
faster then the 42S.
-the display on the 41CL is clear due to the dedicated LCD segments
as opposed to the 42S dot matrix. Much easier to see at night in
low light.
-My CL routines use the dynamic time functions (with module) and
the 42S does not.
AND NOW THE BIG REASON
-Its ability to be fully 'backup and restore' capable is the big
seller for me.
I removed the batteries today, disassembled the calculator, and repaired the solder joint on the LCD panel. Of course this resulted in Memory Lost but who cares. I did not have to use the tape deck, card reader, HPIL or any other mass storage device.
I simply copied the current HP41CL state back into the Memory
from its flash protected storage registers. It took 15 seconds. The memory transfer included all alarms, extended memory data bases and memory registers. Bang, 15 seconds and all of it back.
Tomorrow over to the Simon Fraser University and in 15 seconds I have my Palynology memory swapped from its on board flash location and then back to work on Friday, 15 seconds later and the calculator is configured for the B777 flight.
THANKS MONTE.
I urge anyone using the 41C still to consider the CL upgrade. Unbelievable!!!
Geoff
Edited: 19 Dec 2011, 2:46 p.m.
