WARNING: WARNING: WARNING Message #17 Posted by 聲gel Martin on 20 Dec 2011, 2:39 a.m., in response to message #1 by 聲gel Martin
In the current version (2E) the Backup to Flash uses sector at address 0x0C8, thus if used it will DELETE the Solution Books ROMS.
To prevent this you need to PATCH the code at the following locations in the CLUTILS ROM: (x: = page number).
x0EE, change current value "043" to new value "044"
x0FB, change current value "043" to new value "044"
x105, change current value "043" to new value "044"
This will use sector at address 0x0D8 instead.
You can patch it using YPOKE or HEPAX' HEXEDIT function. CLUTILS needs to be loaded in RAM for this to work.
I'll make this change permanent in version 2F, but in the mean time you'll need to have CLUTILS in RAM to make the changes stated above.
