WP 34S: Current release starts working :-) Message #5 Posted by Marcus von Cube, Germany on 2 Dec 2011, 6:58 a.m., in response to message #1 by Marcus von Cube, Germany
I've made some updates to the latest release so that END should now be working (hopefully). END statements define boundaries for local label search. This includes the hot keys A to D. The program counter needs to be in the program that defines the hot keys to make them active.
GTO.. in program mode goes to the last statement in program memory and adds an END if it isn't already there. In run mode, GTO.. simply goes to step 000. As a short cut, you don't need to press h shift. XEQ. is treated the same as GTO.
GTO.down and GTO.up take you to the next or previous program respectively. This is intended for program mode but may work in run mode, too. I tested it in also library space. All libraries are updated to contain END statements where appropriate. I have not tested this thoroughly, though.
