Re: HP-71B Rom Stuck in Port Message #2 Posted by Raymond Del Tondo on 26 Nov 2011, 9:14 p.m., in response to message #1 by Jeff Davis
If the module sits in port 1 or 2 (near the ON key) ,
you can try to push it out from behind, by removing the IL module (or the cover).
You'll have to use a suitable tool, like an screw driver with isolated shaft.
Be CAREFUL not to damage the PCB or any electronic parts on it!
If the module sits in port 3 or 4, you may have to open the 71B,
by removing the screws under the rubber feet and in the batt and card reader compartments.
HTH
Ray
