Re: WP34S Under WINE Message #5 Posted by Marcus von Cube, Germany on 19 Nov 2011, 12:46 p.m., in response to message #4 by SteveH
Yes, it's a replacement originally written by Cyrille from IBM and only slightly modified to make it compatible with the less than 128KB flash files for WP 34S. The software is much faster than Atmel's offering.
BTW, you will need fresh batteries because the SAMBA boot loader, once activated by erasing the flash with the cable, will have drained them already. Use a multimeter to verify this! If the batteries are still fine, chances are good that you did not successfully erase the calculator. Try to turn it on.
