Re: [WP34s] Bugs in V3.0 Message #50 Posted by fhub on 1 Dec 2011, 8:04 a.m., in response to message #15 by fhub
And again something broken in the latest build SVN 1967: the quadratic solver SLVQ doesn't work anymore!
If I run it without any program loaded (i.e. after a fresh install with "Erased") it just does nothing.
And if I've loaded a program and I'm within this program (i.e. have previously switched to program mode and moved down a few steps), then SLVQ (back in manual mode) seems to execute any step of this program and thus ends up in any error message.
The same if SLVQ is used in a program: in this case SLVQ just seems to jump to any program step.
And a different problem: when I load a flash region with PRCL n, then a simple R/S doesn't start the loaded program - it works only if I first switch to program mode, make at least a SST, go back to manual mode and R/S again.
Edit1: also scrolling with [h][CAT] doesn't work with [up] when at the beginning of the list ([down] at the end works)
Edit2: all mentioned problems did not happen with SVN 1950/51 from 29.Nov.
Franz
Edited: 1 Dec 2011, 10:18 a.m.
