Re: wp34s - Maybe dumb question Message #2 Posted by Paul Dale on 2 Nov 2011, 6:19 a.m., in response to message #1 by John Abbott (S. Africa)
Don't don't don't don't don't call SAVE from a program that is frequently executed. You will destroy the flash in the device :-( Flash has a limited number of write cycles and one is used each time SAVE is executed.
That said, RCF can be used to recall the individual registers you want. Better would be to not use I & J in your code.
Even beter would be to take the V.V routine and remove the stores to I and J:
001 ***LBL'V.V'
002 [cmplx]R[v]
003 RCL[times] T
004 R[^]
005 RCL[times] T
006 +
007 R[^]
008 ENTER[^]
009 RCL[times] T
010 RCL+ Z
011 STO Z
012 DROP
013 STO L
014 DROP
015 RTN
- Pauli
Edited: 2 Nov 2011, 6:19 a.m.
