Re: HP-15C LE -- endless loop in SOLVER Message #3 Posted by uhmgawa on 27 Oct 2011, 3:33 p.m., in response to message #2 by Jeroen Van Nieuwenhove
Interesting. The 15C emulator in Nonpareil gets stuck at the first error message, as would be expected. I suppose the original 15C behaves the same. This is strange, since the 15C LE is based on the same firmware. The error handling seems to be influenced in some way.
I'd be quite surprised if this was due to a change in the
firmware error handling behaviour peculiar to the 15c le.
Gerson, is the alternating between "running" and "Error 0"
occurring at the same rate of the display blink frequency?
[I don't have a 15c le handy ATM.] If so I'd make a wild
guess this is somehow due to the display update minimization
logic along with an interaction of exiting the emulator driven
display blink mode. Although I can't really think of a reason
a shadow of the prior display contents would be needed.
Running this on KEMU I find the expected behaviour. The display
update sequence preceding this point looks quite vanilla as well
so I don't have a better guess.
