Re: 15C-LE Blinking Message #17 Posted by uhmgawa on 26 Oct 2011, 4:45 p.m., in response to message #16 by Miguel Toro
Well, not any key, as an example, numerical keys do not disable blinking. You have to use backspace or ON/OFF on the 15c.
I believe we're tripping over semantics here.
From the perspective of the r2d2 display hardware, each
key press results in a DISOFF instruction being emitted by
the firmware which disables blink mode. However this isn't
apparent to the user as the firmware reenables blink mode
(via a DISBLINK/0x030 instruction) during its routine update
of the display when flag 9 is set.
