HP Forum Archive 20
HP-65 strange card writing error
Message #1 Posted by John Garza on 21 Oct 2011, 2:56 a.m.
I have an HP-65 that I refurbished a few yars ago (new drive roller, clutch, cleaned head & leaf switches, etc. and well lubed).
It was working perfectly until today. I can read cards fine. I can write cards and then read them back in and get a steady "0.00".
However, when I switch to W/PRGM, in addition to the normal keycode display, I see minus signs at the left and right ends of the display. And the program does not run properly, the display just flickers dimly. This strange behavior only happens with cards that I have recently written to. Standard Pac cards, and cards I recorded a month ago read and run properly and don't display the minus signs.
AFAIK, the most likely culprit with write failures is the leaf switches. But I have not read any mention of the strange display. Could the switches be "marginal" - making intermittent contanct (somehow getting out of adjustment by just sitting on a shelf)? or maybe some electronics are finally dying (caps, coils, etc.)
Anyone seen this before?
-John (3665)
Re: HP-65 strange card writing error
Message #2 Posted by Rik Bos on 21 Oct 2011, 3:08 p.m.,
in response to message #1 by John Garza
Hi John,
Did you replaced the tantalium caps next to the head amplifier circuit and on the back of the motor ? A lot of strange cardreader errors are caused by a cap with a high ESR value. Also important is the condition of your battery pack because the head amplifier gets it supply directly form the battery, if the internal resistance of the pack is getting high you also get unpredictable results. A bad battery pack also causes the a short battery life.
-Rik
Re: HP-65 strange card writing error - Caps values?
Message #3 Posted by AlbertTocarLoseggs on 21 Oct 2011, 4:41 p.m.,
in response to message #2 by Rik Bos
Hi Rik, Which are the values of these tantalum caps? Are the same for an HP-67? Thanks, Albert
Message #4 Posted by Rik Bos on 21 Oct 2011, 5:39 p.m.,
in response to message #3 by AlbertTocarLoseggs
Hi Albert,
According to the HPCC schematics from Tony Duell they are 22uF, there is also one on the motor for supression of the commutation spikes. Keep in mind that Tony some times makes a typo so the value could also be 2.2uF, but you'll see the value when you open the calculator.
-Rik
