Re: 34S Matrix Questions Message #2 Posted by gene wright on 14 Oct 2011, 5:16 p.m., in response to message #1 by Egan Ford
The library files are in a download area on the sourceforge site.
You download those files and then use Samba to load them to different locations in the 34S from the main location to flash the firmware.
Libraries 1 through 5 can go to these offsets:
0x11f400 - Library 1
0x11f000 - Library 2
0x11ec00 - Library 3
0x11e800 - Library 4
0x11e400 - Library 5
I have been intending to write this up because I could not figure out how to do this either.
I have a write up (thanks Marcus and Pauli for being so patient with my questions), but your questions confirm the need for better instructions.
The library files as they exist now can be found here:
34S Library directory on Sourceforge
Each file is named wp34s-5.dat, etc.
The order really does not matter, but if a library has the same 3 character label as another, the label in the lowest numbered library gets executed if called.
