Re: What is the SVN version of 34S that does NOT need a keyboard change? Message #4 Posted by Jeff O. on 14 Oct 2011, 1:59 p.m., in response to message #1 by Egan Ford
The latest version, 1726, uses the current keyboard (i.e the one for which Eric's overlay works.) It has the "41C" enhancements, i.e., the function name is displayed when you press a key and NULLs out if you hold the key down for few seconds. (This feature will help when they change the keyboard, if one decides to keep loading new versions without changing the overlay.)
The above is incorrect, version 1722 is the last version that is fully compatible with Eric's overlay. See the following posts. I never used the old functions that are gone and like the new, so I can live with the change.
Edited: 14 Oct 2011, 4:53 p.m. after one or more responses were posted
