Re: 27S display - a show stopper? Message #10 Posted by uhmgawa on 12 Oct 2011, 1:00 a.m., in response to message #9 by Lyuka
for more information about it, take a look at
'A work-around for sticking-to-low-contrast LCD problem of the HP-42S'
and previous thread 'An HP-42S fix success, and a contrast problem'.
Ah, I think I see what my confusion was above. You were
describing low contrast due to insufficient lcd polarization drive resulting in a faint display vs. the low contrast
inherent in this series of lcds under normal operation.
The latter problem is due to the intended "off" pixels receiving
an average multiplex voltage just over their polarization
potential which partially enables them, thereby reducing the
contrast ratio due to saturation. AFAICT it really looks to be
an issue of the controller either logically in terms of excessive
multiplex ratio (or less likely analog drive) either of which
results in RMS voltages (and optical polarization states) for
on vs. off being too close causing readjustment of the lcd drive
rail to be needed as the viewing angle changes.
This appears unrelated to a glass quality issue as the
polarization level doesn't seem to visibly ghost due to
crosstalk and the partial polarization is uniform. While
these displays perform rather poorly by modern standards
I seem to recall this being typical of matrix displays
around the time these calculators were developed.
The PCB and the LCD of the 27S is identical to that of the 42S.
The 17B I peeled open was very close except for what appeared
to be a few cosmetic layout changes. Unsure whether that was
model specific or a uniform change made to all models relative
to manufacturing date (probably the latter).
