HP Forum Archive 20
Crystal to my 30b
Message #1 Posted by robertoataulfo on 4 Oct 2011, 4:06 p.m.
To make the time functions accurate, it requires adding a crystal to my 30b.
Has anyone compiled a parts list and where to put them in a 30b?
Can I use this crystal for this purpose?
http://commerce.hpcalc.org/20bkit.php
Edited: 4 Oct 2011, 4:07 p.m.
Re: Crystal to my 30b
Message #2 Posted by Walter B on 4 Oct 2011, 4:44 p.m.,
in response to message #1 by robertoataulfo
Marcus is our soldering expert here. He will tell you :-)
Message #3 Posted by Marcus von Cube, Germany on 4 Oct 2011, 4:44 p.m.,
You just need the crystal and the two capacitors for the modification. Be prepared for some frustration while trying to solder the tiny parts to the barely appropriate solder pads. But its worth the effort and makes the serial interface much more reliable.
Message #4 Posted by Gerry Schultz on 4 Oct 2011, 5:17 p.m.,
in response to message #3 by Marcus von Cube, Germany
Hey Marcus, I asked Eric Rechlin of Hpcalc.org at the end of the HHC conference about this and he says he will be putting together a kit of parts needed to add a crystal to a 30b sometime before the end of the year. I too am interested in adding the crystal and capacitors to my 30b and if I had the values for the parts I could order them myself. But being a lazy person, having Eric put together the parts is good too.
Gerry
Message #5 Posted by robertoataulfo on 4 Oct 2011, 7:36 p.m.,
Marcus are these items?
Message #6 Posted by Marcus von Cube, Germany on 5 Oct 2011, 1:52 a.m.,
in response to message #5 by robertoataulfo
Yes, but you just need:
  • 18 pF 0603 capacitors (quantity 2)
  • 32.768 kHz clock crystal (quantity 1)
Message #7 Posted by E.Lub_EU on 7 Oct 2011, 10:49 a.m.,
Roberto,
As Marcus mentionned in his reply, you only need a crystal and 2 capacitors to add to your 30b. One caveat is that the crystal has to be "compatible" with the capacitors chosen. Eric will have taken care of that in his kit.
If you do not get the kit through Eric, please verify that you order a crystal that is specified for a 12pF capacitive load (this parameter is often designated as "CL" in the specification sheet).
Hope this helps.
Good luck!
Etienne
