Re: 15C Keyboard Issues [UPDATE- DO NOT EMAIL ME] Message #17 Posted by uhmgawa on 3 Oct 2011, 6:55 p.m., in response to message #10 by robert rozee
BTW, has anyone got photos of a disassembled 2xCR2032 HP-12C showing the actual keyboard construction/design. had a bit of a look with google, found various comments from 'experts' but no actual photos.
I just uploaded some -- see above post in this thread.
Note the choice of legged snap dome was functional as the
dome-side pcb routing takes advantage of this. So if you'd
like to get the tactile feel of a legacy voyager you could
cover the center contact trace exit with a strip of kapton tape
and substitute a full circular dome. The original voyager
domes are 9mm with a 150~170g actuation force. I forget
what I'd measured the 4 legged domes on the 12c+ (and presumably
15c le) to be, but I'll recheck.
Added:
The 4 legged domes in the 12c specimen I have at hand are
8.36mm in diameter with an approximate 220g inflection force.
Assuming this is representative of average production, the force
needed to actuate a 12c dome is substantially greater than legacy
voyager counterparts. Cut/legged domes also have a sharper
transition compared to the full domes of the same diameter,
which is likely the cause of the tactile difference.
Edited: 4 Oct 2011, 11:25 a.m.
