HCC2011 and some 15LE observations Message #1 Posted by geoff quickfall on 22 Sept 2011, 9:56 a.m.
Sitting at the airport waiting for my early morning flight. For all those travelling to HCC; by car or air, have a safe journey and see you there.
Wlodek and I are meeting in LAX, then a slow drive to San Diego and at the hotel by Thursday night. See you in the lobby.
My two HP 15LE arrived yesterday, serial numbers at the 500 level. No crooked or loose keys.
Interestingly enough: if you are QUICK, you can get the classic keyboard test to work:
Invoke the test with "/ and the ON key" and then quickly press the square root key and then each succesive key as with the 15C.
You just have to get to the square root key quickly or you get error 9. Once completed the classic 15 will show in the centre of the display.
Of course the new tests are similar to the HP 12:
"g" + "ENTER" pressed together then the "ON"key.
And in case it has not been explained well enough, the flashing porcedure for the 15LE is the same as flashing the 34S. Cable, Samba and away you go.
Cheers, Geoff
Cheers, Geoff
