Re: Does anyone have 15C LE dissection pics? Message #12 Posted by Kerem Kapkin (Silicon Valley, CA) on 21 Sept 2011, 12:49 p.m., in response to message #7 by Katie Wasserman
Spec details on Atmel AT91SAM7L128
A member of the Atmel SAM7L series of microcontrollers based on the 32-bit ARM7TDMI processor. It operates at a maximum speed of 36MHz and features 128KB of flash and 6KB of SRAM. The peripheral set includes a 40-segment LCD controller, two USARTs, UART, SPI, TWI (I2C), three 16-bit timers, RTC and four 10-bit ADC. The SAM7L128 operates in single-supply mode down to 1.8V and consumes 0.5mA/MHz typical in active mode when executing code out of its flash memory, and a mere 100nA in power-down mode. The SAM7L128 is supplied in a 128-pin LQFP and 144-pin LFBGA packages.
It is the SAME Chip on HP20b Calculator:
HP20b Calculator using ATMEL 91SAM7L128 Chip
Another good article about the 15c and ATMEL Processor
EDA360 15C and ATMEL AT91SAM7L128 (BTW, I think that's where the "inmate" discussion started in the forums.)
Edited: 21 Sept 2011, 1:26 p.m.
