HP Forum Archive 20
PSE bug also in Integrate and Solve
Message #1 Posted by Namir on 18 Sept 2011, 4:05 p.m.
Hi All,
The PSE bug also appears when you use the Integrate or Solve command and the targeted label has a PSE command (usually put there to trace the X values used by either command). The first time the machine encounters the PSE command it pauses and displays the value in the X register. Subsequent iterations will cause the LCD to blank out until the Integrate or Solve command has finished its task.
Namir
