Classic HP LED failure diagnosis Message #1 Posted by aj04062 on 16 Sept 2011, 9:51 p.m.
I have a 65 that has a non-lighting minus sign. Upon dis-assembly, it can be observed that the Cathode 1 segment does seem to light very faintly when the CHS key is pressed. The minus sign does not light.
Upon additional testing, when the battery drains and all the decimal points light up, the Cathode 1 decimal point DOES LIGHT UP. This leads me to believe that it is likely the LED Module and not the Cathode driver.
does anyone concur with this diagnosis?
