Re: HP 28S saw 36V versus 4.5V, damage and repair? Message #4 Posted by Alexander Oestert on 10 Sept 2011, 2:01 p.m., in response to message #1 by Joshua Keena
Recently I also got an HP 28S off of ebay and the seller had unknowingly included three 12V batteries from his garage door opener which really look surprisingly similar to the correct 1.5 V batteries. Not checking I inserted them right after opening the box and the calculator emitted some very strange sounds but doing nothing else. I guess I tried and tried for at least two minutes before even suspecting something wrong with the voltage. After inserting some of the spare 1.5 V cells I always keep for my 41's the 28S works flawlessly!
I hope yours will do, too, after only some minor surgery!!!
P.S. Have you checked the battery door to be correctly closed? That thing is a bit wobbly and might cause connection problems.
