HP Forum Archive 20
WP 34S : Reopening last catalog called - Revisited
Message #1 Posted by Miguel Toro on 9 Sept 2011, 12:44 p.m.
Hello team 34s,
I flashed the new firmware and tested the "last catalog called" feature, and it worked...beyond expectation: now, even if you turn off the calculator, the last position is kept. That is really nice...a little la 42s. What is needed is a small change on the manual, page 66, so to delete "This position is lost when the WP 34s is turned off." :-)
Thanks and regards,
Miguel
Re: WP 34S : Reopening last catalog called - Revisited
Message #2 Posted by Marcus von Cube, Germany on 9 Sept 2011, 1:01 p.m.,
in response to message #1 by Miguel Toro
That the position used to be lost across a power cycle was actually a bug in an internal routine. But if Walter insists I can make the software behave the way the manual describes. ;-)
Message #3 Posted by Walter B on 9 Sept 2011, 2:58 p.m.,
in response to message #2 by Marcus von Cube, Germany
I don't insist ;-)
Message #4 Posted by Walter B on 11 Sept 2011, 5:00 p.m.,
Page 66 is changed and committed.
