Re: has 16C memory increased? Message #2 Posted by Eric Smith on 5 Sept 2011, 8:39 p.m., in response to message #1 by designnut
The 16C has been discontinued since 1988, so none of its specifications have changed since then.
If you are referring to the new 15c limited edition, AFAIK the only specifications that are changed are the speed (much faster) and the batteries (two CR2032, vs. three 357 button cells). The available memory is unchanged: up to 65 registers or 448 program steps.
