Re: Large pic of 15c LE and 30th anniversary - you can download these too Message #7 Posted by Lode on 2 Sept 2011, 6:01 p.m., in response to message #1 by Gene Wright
If you place both images on top of each other (or align them exactly the same in two browser tabs and switch the tabs) you can see that the leathery pattern on the sides is exactly the same on both. Is that leathery pattern made in such a way that it has the same pattern on every calculator?
What I mean is, in the top left, top right and bottom left of the calculators especially, the bumps and lower spots, the black and white spots, are the same.
