Re: Card Reader pressure roller diameter? Message #7 Posted by Ian Phillips on 28 Aug 2011, 5:47 p.m., in response to message #6 by Dan W
If this is the same roller in the 65/67/97 card readers, I have a spare I could mail you.
If you want to make your own, be advised the pin/cam on the end is slightly offset so that rotating the roller will change the pressure. I have a good photo of the end showing this offset, from which you could take some measurements, if that would help.
Send me an email if interested in either.
-- Dan
Thanks for the offer, but I have made a PTFE roller that runs on a pin that is a snug fit in the recesses. The card move through cleanly every time but I have not managed to find what is causing the 'Malfunction' or Checksum Error messages since I reassembled it, although it was working fine last time I used it (about 6 years ago!)
Using the card reader with new 'N' cells I sometimes get the 'Low batt' message too. I have an old (single) memory module that I am thinking of using as a temporary connector so that I can measure the battery volts on load or alternatively use a bench PSU to see just how much current is being drawn.
Ian
Ian
