Re: question for lyuka and the Ostrowski method - bumped! Message #4 Posted by Lyuka on 25 Aug 2011, 10:01 p.m., in response to message #1 by hugh steers
Hi hugh steers, Namir and all who interested.
I've modified the code (Rev.2.94) to struggle to escape from the flat region or extremes, this morning.
Now, it can solve the water saturation pressure equation started at the very flat region e.g. [-273.15, -273.0].
Please try the latest code (Rev.2.94).
/*s(x) : Water saturation pressures (Sonntag)*/
double
s(x)
double x;
double t;
double p = 1e-5;
t = x + 273.15;
if (t < 0) return -p;
return exp(((16.635794 + 2.433502 * log(t) + 0.00001673952 * t * t) - 0.02711193 * t)
- 6096.9385 / t) - p;
main: s(t) is 'P_water_sat_Sonntag'
ost:a=-273.15, b=-273.1, c=-273.125, f=-1.000000000000e-05, i=0, p=0
ost:a=-273.15, b=-273.225, c=-273.206078387, f=-1.000000000000e-05, i=1, p=1
ost:a=-273.15, b=-273.0375, c=-273.064372309, f=-1.000000000000e-05, i=2, p=2
ost:a=-273.15, b=-273.31875, c=-273.295157305, f=-1.000000000000e-05, i=3, p=3
ost:a=-273.15, b=-272.896875, c=-273.090425146, f=-1.000000000000e-05, i=4, p=4
ost:a=-273.15, b=-273.5296875, c=-273.285100373, f=-1.000000000000e-05, i=5, p=5
ost:a=-273.15, b=-272.58046875, c=-272.731564881, f=-1.000000000000e-05, i=6, p=6
ost:a=-273.15, b=-274.004296875, c=-273.411032864, f=-1.000000000000e-05, i=7, p=7
ost:a=-273.15, b=-271.868554688, c=-272.448762741, f=-1.000000000000e-05, i=8, p=8
ost:a=-273.15, b=-275.072167969, c=-274.073068154, f=-1.000000000000e-05, i=9, p=9
ost:a=-273.15, b=-270.266748047, c=-271.383252597, f=-1.000000000000e-05, i=10, p=10
ost:a=-273.15, b=-277.47487793, c=-274.800747146, f=-1.000000000000e-05, i=11, p=11
ost:a=-273.15, b=-266.662683105, c=-269.830272597, f=-1.000000000000e-05, i=12, p=12
ost:a=-273.15, b=-282.880975342, c=-281.866044434, f=-1.000000000000e-05, i=13, p=13
ost:a=-273.15, b=-258.553536987, c=-260.536164572, f=-1.000000000000e-05, i=14, p=14
ost:a=-273.15, b=-295.044694519, c=-286.697293227, f=-1.000000000000e-05, i=15, p=15
ost:a=-273.15, b=-240.307958221, c=-250.48456364, f=-1.000000000000e-05, i=16, p=16
ost:a=-273.15, b=-322.413062668, c=-282.332745028, f=-1.000000000000e-05, i=17, p=17
ost:a=-273.15, b=-199.255405998, c=-229.286334046, f=-1.000000000000e-05, i=18, p=18
ost:a=-273.15, b=-383.991891003, c=-281.658556097, f=-1.000000000000e-05, i=19, p=19
ost:a=-273.15, b=-106.887163496, c=-227.42340973, f=-1.000000000000e-05, i=20, p=20
ost:a=-273.15, b=-106.887163496, c=-242.794125415, f=-1.000000000000e-05, i=21, p=21
ost:a=-273.15, b=-106.887163496, c=-145.766953091, f=-9.999848970363e-06, i=22, p=22
ost:a=-106.887163496, b=-145.766953091, c=-106.88706331, f=-1.155857857677e-06, i=23, p=22
ost:a=-145.766953091, b=-106.88706331, c=-106.338424292, f=-6.002266450796e-08, i=24, p=22
ost:a=-106.88706331, b=-106.338424292, c=-106.311453476, f=-2.988926674806e-09, i=25, p=22
ost:a=-106.338424292, b=-106.311453476, c=-106.310044116, f=-1.842629348946e-13, i=26, p=22
ost:a=-106.311453476, b=-106.310044116, c=-106.310044029, f=1.496866036476e-20, i=27, p=22
main: -273.15, -273.1, s(-106.310044029) = 1.49686603648e-20, r=1
And also, it can find a root of (x-1)^5 in 27 iterations.
/* f6(x) = (x-1)^5 */
ost:a=0, b=1.5, c=0.75, f=-9.765625000000e-04, i=0, p=0
ost:a=1.5, b=0.75, c=0.761904761905, f=-7.651622719419e-04, i=1, p=0
ost:a=0.75, b=0.761904761905, c=0.803189200351, f=-2.952872052788e-04, i=2, p=0
ost:a=0.761904761905, b=0.803189200351, c=0.850693877302, f=-7.419729755354e-05, i=3, p=0
ost:a=0.803189200351, b=0.850693877302, c=0.878293985111, f=-2.670300955364e-05, i=4, p=0
ost:a=0.850693877302, b=0.878293985111, c=0.902610176346, f=-8.761286801440e-06, i=5, p=0
ost:a=0.878293985111, b=0.902610176346, c=0.92234070912, f=-2.824666003999e-06, i=6, p=0
ost:a=0.902610176346, b=0.92234070912, c=0.937768603186, f=-9.333569060579e-07, i=7, p=0
ost:a=0.92234070912, b=0.937768603186, c=0.950216234015, f=-3.058008812555e-07, i=8, p=0
ost:a=0.937768603186, b=0.950216234015, c=0.960176299828, f=-1.001631669682e-07, i=9, p=0
ost:a=0.950216234015, b=0.960176299828, c=0.968133427318, f=-3.286069794729e-08, i=10, p=0
ost:a=0.960176299828, b=0.968133427318, c=0.974504259003, f=-1.077303803554e-08, i=11, p=0
ost:a=0.968133427318, b=0.974504259003, c=0.979601206998, f=-3.532013499117e-09, i=12, p=0
ost:a=0.974504259003, b=0.979601206998, c=0.983678883914, f=-1.158108552378e-09, i=13, p=0
ost:a=0.979601206998, b=0.983678883914, c=0.986941586119, f=-3.797100974770e-10, i=14, p=0
ost:a=0.983678883914, b=0.986941586119, c=0.989552033388, f=-1.244969983086e-10, i=15, p=0
ost:a=0.986941586119, b=0.989552033388, c=0.991640629072, f=-4.081952835848e-11, i=16, p=0
ost:a=0.989552033388, b=0.991640629072, c=0.993311710543, f=-1.338367252555e-11, i=17, p=0
ost:a=0.991640629072, b=0.993311710543, c=0.994648733138, f=-4.388165984146e-12, i=18, p=0
ost:a=0.993311710543, b=0.994648733138, c=0.995718477996, f=-1.438768435661e-12, i=19, p=0
ost:a=0.994648733138, b=0.995718477996, c=0.996574375736, f=-4.717355769657e-13, i=20, p=0
ost:a=0.995718477996, b=0.996574375736, c=0.99725917517, f=-1.546701119566e-13, i=21, p=0
ost:a=0.996574375736, b=0.99725917517, c=0.997807079768, f=-5.071240091293e-14, i=22, p=0
ost:a=0.99725917517, b=0.997807079768, c=0.998245455502, f=-1.662730778483e-14, i=23, p=0
ost:a=0.997807079768, b=0.998245455502, c=0.998596197729, f=-5.451671807322e-15, i=24, p=0
ost:a=0.998245455502, b=0.998596197729, c=0.99887682483, f=-1.787464685796e-15, i=25, p=0
ost:a=0.998596197729, b=0.99887682483, c=0.999101353168, f=-5.860642591876e-16, i=26, p=0
ost:a=0.99887682483, b=0.999101353168, c=0.999280997168, f=-1.921555815013e-16, i=27, p=0
main:f6: 0, 1.5, s(0.999280997168) = -1.92155581501e-16, r=1
Lyuka
Edited: 25 Aug 2011, 11:59 p.m.
