Re: HP-30b successfully re-flashed to a WP-34s in Vista with SAM-BA 2.10 & USB-RS232 converter Message #3 Posted by Hubert Weikert on 21 Aug 2011, 1:49 p.m., in response to message #1 by Bart (UK)
Good news, thank you for!
Still trying to get SAM-BA working with the WP34S on Linux. Unfortunately Atmel supports on Linux only the CDC version. Serial SAM-BA requires some specialities not supported by the CDC variant, like sending some kind of sync characters for auto-baud initialisation, and probably others.
I use a FTDI chip based USB-to-serial converter.
Promising is the open source Sam-I-Am tool, but designed also only for CDC. Initial sync and auto-baud work now, but other commands except SAM-BA version query fail.
A further, less comfortable alternative for flashing may be sam7utils but up to now I get errors when the program tries to open the usb-serial port, with invalid ioctl() calls.
Hubert
