Re: 34S matrix programs Message #9 Posted by gene wright on 11 Aug 2011, 5:47 p.m., in response to message #8 by Walter B
Good! No wonder you made many very good decisions on the 34s. ;-)
But, what I am working on is a very vanilla port of M1 through M5, BX, QR, BE from the PPC ROM and then RRM and MIO from the M1 routines application programs.
First draft, which should fit into the 506 step flash bank with few problems, will not use the REG-SWAP features of the 34s because the programs are written assuming XX.YY in X and TT.ZZ in Y for register swaps, for example. Once it is working then refinements can be worked on.
So, no secret what these will look like. They will be as much like those in the PPC ROM manual as possible. :-)
