HP 41C display problem Message #1 Posted by Alexander Oestert on 11 Aug 2011, 4:01 a.m.
Hi experts!
I have recently acquired a 41C, serial No. 1947..., with a screwed on CPU PCB, so not easily removed.
Keying in numbers or letters shows something like this
The flaw occurs on the third position from the left, its shape depending on the number/character I'm keying in on the first (!) position. Most characters give something like an R shape on the third position, characters like "I", "J", "1" or "7" will produce a more slender shape in the third display position. In any case there is also an underscore in the second position and some semicolon and points all around. If this is too hard to understand I will make a video... ;)
I've helped myself by putting a program on a key in USER mode that shifts the display by four alpha spaces to the right. But this is not very convenient.
Does anyone know what can be done against this? Is it a matter of (ultra sonic) cleaning the keyboard and display? Is the graphic engine gone for good?
Thanks in advance!
