Re: CostCentral (Erie) update on HP-15C LE Message #3 Posted by Thomas Radtke on 10 Aug 2011, 3:40 p.m., in response to message #2 by Lode
To enter the european market, you need to translate documentation and ensure compliance to local regulations. That could be a reason to have a later launch over here, if that will be the case in the first place.
It's interesting that I can still import it as a private person. Did so with the 35s and, of course, got english docs, which violates the regulations. Hopefully, it works out with the 15C LE the same way.
The cost is probably the same.
