Re: WP34S: cpx DROP & CLx ? Message #16 Posted by Walter B on 4 Aug 2011, 5:10 p.m., in response to message #15 by Paul Dale
You're right. The manual is corrected now but not committed yet :-)
And you're right again: Every complex operation not accessible on the keyboard directly is found in [CPX][X.FCN]. Thus that's the place to find [^c]DROP as well 8-)
Some background: Sorting items in catalogs is not trivial, since ASCII has some very special order for whatever historical reason. So we had to define our own sorting sequence. By no means, however, you'll get e.g. [^c]DROP following DROP directly in a sorted list.
And finally, [CPX][CLx] doesn't give any return on invest. You'll reach the same result via [CLx][CLx] with the same number of keystrokes.
Walter
Edited: 4 Aug 2011, 5:12 p.m.
