Re: WP34S: more direct LBLs and XEQs Message #2 Posted by Marcus von Cube, Germany on 31 July 2011, 12:59 p.m., in response to message #1 by fhub
You have overlooked something. GTO.nnn moves the PC directly to a step number. This isn't a programmable command but its existence makes it impossible to input a GTO X statement. And a label which cannot be reached by all available commands is not as useful as it could be. So we decided to leave this one out.
BTW, the change triggered another change because we have again exhausted all flash. In order not to lose another library region, I have started moving things from XROM to a default library. 'WHO' is already gone from XROM and TVM will leave next. They are not lost but you need to install a library file on the emulator or the device to get them back.
Edit: The change is in (TVM and an enhanced WHO are now in a library.)
A new command, LSEND n, directly sends a library region from the emulator to the calculator (where it arrives in RAM first). The command name may change later but the function will likely not.
Edited: 31 July 2011, 2:27 p.m. after one or more responses were posted
