SpeedUI 11.07 supports RainEQ Message #1 Posted by Raymond Del Tondo on 30 July 2011, 11:07 p.m.
Hello all,
here's an update for SpeedUI.
SpeedUI 11.07 is a minor update only, but with deep impact for users of the
Eqation Writer.
If RainEQ (raineq.lib) is installed, it will be used instead of the built-in
EQW.
This means that existing equations will be edited in RainEQ,
and new eqations will be created using RainEQ.
The display/editing speed difference is dramatical:
The built.in EQW needs much time to display the equation,
but RainEQ displays the equation nearly instantly!
RainEQ and some related documentation is available on www.hpcalc.org .
For installation/uninstallation, please take a look into
StartHere.pdf supplied with the latest SpeedUI archive.
The new version is available here:
http://www.hpmuseum.org/guest/deltondo/speedui.pdf (Walkthrough PDF)
http://www.hpmuseum.org/guest/deltondo/sui_1107.zip (SpeedUI zip archive)
but not on www.hpcalc.org (since the site has not been updated for a long
time)
Have fun:-)
Raymond
