34S broken build :-( - Please update! Message #1 Posted by Marcus von Cube, Germany on 26 July 2011, 3:07 a.m.
I've just fixed a major problem with writing to flash. Power saving is a nasty thing on this platform.
You will need to update your device before you try to write to flash! If you have already loaded user code that you do not want to lose, use the new serial I/O to backup to the emulator first.
Edited: 26 July 2011, 3:11 a.m.
