Re: HP-28S Keyboard Message #4 Posted by Geoff Quickfall on 26 July 2011, 2:27 p.m., in response to message #3 by Ron Ross
Got to mildly disagree with the following Ron:
high probabilty of failure
of course, it is dependent on how much time you want to input. This repair was done over two hours with an overnight set on the styrene solvent.
Problem is, this is such a ubiquitous failure (design) at the latch area heat stakes that finding a donor will be problematic. Just ask Randy and his 19BII failure rate.
In any case (pun intended) I have repaired 7 of these in the manner indicated and they are running perfectly! Use the 28S pictured in cockpit to see how durable the new stakes are and the foam replacement is.
Working fine, great machine, poor case design. Now if the hinge was broken then that would be a different story.
Cheers, Geoff
Edited: 26 July 2011, 2:28 p.m.
