Corrected command to build WP 34S assembler tables Message #1 Posted by Neil Hamilton (Ottawa) on 25 July 2011, 6:38 a.m.
Hi All,
There is a typo in the Assembler documentation regarding building new opcode tables for SVN revision translations. Section 5.2, Figures 5.2 and 5.3, give incorrect command lines for doing this. The command line parameter "opcodes" is missing.
The correct command is (your path may vary):
$ calc opcodes > svn_XXXX.op
I will issue an updated manual in the next little while.
Sorry for the inconvenience (and thanks for spotting this Cristian!).
