41 HP-IL: How to reset? Message #1 Posted by 聲gel Martin on 17 July 2011, 2:00 a.m.
Recently two of my 41's refused to be operational on the IL loop. Only TRANSMIT ERR messages, both with the 'real' loop and the Pil-Box. Even with no device on the loop, closing both connectors together.
A third machine was working perfectly, so I knew the interface wasn't the issue.
Memory Lost brought them back to a more cooperative state, it all works fine now.
I'm a bit rusty on HP-IL operation, is there any other reset procedure that doesn't involve ML?
Also any ideas as to what caused it in the first place? I'm swapping modules very often amongst the three units, maybe some of them caused the issue...
Best,
'AM
Edited: 17 July 2011, 2:07 a.m.
