34S - Problem With CLx Message #1 Posted by Jake Schwartz on 16 July 2011, 1:50 p.m.
While debugging a program on the 34S side-by-side with a 15C, I noticed that in the 34S, currently CLx leaves stack lift enabled, which is not the way HP calcs work. In the HP machines, the purpose of disabling stack lift with CLx was so if an erroneous number was entered, CLx would allow entering a replacement value without affecting the stack. For consistency, they kept this behavior the same while running in a program as well.
Hopefully, it makes sense to change this so it works in the 34S like all other RPN machines.
Thanks,
Jake
