Re: HP 41 battery Shield - what is it ? Message #3 Posted by Raymond Del Tondo on 15 July 2011, 7:12 a.m., in response to message #2 by Klaus
The rivets are intentional, for at least two reasons:
- Work with slightly damaged contact foils
- Do not add too much material between the contact foil and the batt poles
The battery shield as such should:
- Protect the foil from leaking batts
- Add some extra retention for the batts when not in the calc
The idea was not bad, but the pre-perforation of the contact foil is a no-go, so I would not recommend using the shield.
