Re: Board Stacking Connector HP-9815 Message #2 Posted by Joel Setton (France) on 14 July 2011, 4:26 p.m., in response to message #1 by aj04062
I haven't seen them anyplace but in a 9815. Must have been one of these special, non-standard things that were typical HP fashion.
I did kludge one by splitting a standard PC-edge connector along its length, then gluing the two halves back-to-back with epoxy. After that, a little dose of point-to-point soldering to bridge the contacts did the trick. It didn't look good but it got the calculator to work!
Joel
