Re: WP34s - Verifying Flashing Message #4 Posted by Marcus von Cube, Germany on 10 July 2011, 2:36 p.m., in response to message #2 by Walter B
Thomas,
the HP procedures assume that you're flashing a firmware from them. If you reflash the 20b/30b with another 20b/30b image you get a 20b/30b which responds to ON+D as documented by HP.
If you reflash the 20b/30b with a WP 34S image you get a WP 34S which responds to ON+D as documented by Walter. :-) There is not a single bit of HP code left after reflashing and therefore HP's documentation about the behavior of you calculator no longer holds.
One of the differences concerns the reflashing process itself: There is no longer the need to clear all of flash memory in order to get the device into SAM-BA boot mode. ON+D followed by a double ON+S (ON+6) does the trick. The documentation tells you more about the details. The main benefit is that this will preserve a previously created backup of the RAM in your calculator and all installed libraries.
If the calculator boots you can be pretty sure that the flashing has completed. If you are in doubt, SAM-BA provides a verify mechanism.
Edited: 10 July 2011, 2:37 p.m.
