HP Forum Archive 20
50G has stopped plotting?
Message #1 Posted by Glenn Becker on 9 July 2011, 6:36 a.m.
Good morning all -
I am being driven nuts by this and don't have my manuals handy ... but my 50G seems to no longer be drawing plots, even of simple functions. I get coordinate axes ... if I ask the calc for things like slope, etc. I get the correct values, but no plot is drawn.
I have tried setting/unsetting a few flags, but nothing has helped.
I have tried resetting the unit by pressing ON F3 (and alternatively by pushing a paper clip into the small hole in the back) but I am not sure the unit is resetting properly, either: I get a brief flash of the "powered by <something> kernel" and then the display is immediately back -- with, apparently, the same settings.
I'm sure I'm doing something silly, but I can't figure out what it is.
Glenn
Re: 50G has stopped plotting?
Message #2 Posted by Glenn Becker on 10 July 2011, 6:21 p.m.,
in response to message #1 by Glenn Becker
I wound up doing a complete reset by removing all the batteries. I think I just had the calc at some extreme zoom level or something. All better now, and learning more about this unit every day. :^)
Message #3 Posted by Chris Randle (UK) on 11 July 2011, 6:01 p.m.,
in response to message #2 by Glenn Becker
Hi Glenn,
If it was a case of an extreme zoom level, then you can reset it by purging the PPAR variable in the current directory. You can change the zoom level with LS+WIN (press and *hold* the white left-shift key and press F2). Edit the min and max H-View values to something better. -6.5 to 6.5 is the default. The Auto key (F4) will adjust the V-View for the current H-view range.
An alternative way to do a machine reset is ON+A+F and answer "NO" to "Try To Recover Memory?"
