Re: The Prime Factors Kata Message #3 Posted by Thomas Klemm on 27 June 2011, 3:32 p.m., in response to message #2 by Eddie W. Shore
When you run the disassembly through this script a lot of the translation is done:
#!/usr/bin/perl -w
while (<>) {
printf "%-22s; $_%s",
/[adfil]?return/ ? 'RTN' :
/dup/ ? 'ENTER' :
/swap/ ? 'X<>Y' :
/[dfil]const_(\d)/ ? $1 :
/iconst_m1/ ? -1 :
/[dfil]load_(\d)/ ? "RCL 0$1" :
/[dfil]load\s+(\d+)/ ? sprintf("RCL %02d", $1) :
/[dfil]store_(\d)/ ? "STO 0$1" :
/[dfil]store\s+(\d+)/ ? sprintf("STO %02d", $1) :
/goto\s+(\d+)/ ? sprintf("GTO %02d", $1) :
/iinc\s+(\d+),\s+(\d+)/ ? ($2, sprintf "STO+ %02d\n", $1) :
/[dfil]add/ ? '+' :
/[dfil]sub/ ? '-' :
/[dfil]mul/ ? '*' :
/[dfil]div/ ? '/' :
/[dfil]rem/ ? 'MOD' :
/ifeq\s+(\d+)/ ? ('X=0?', sprintf "GTO %02d\n", $1) :
/ifne\s+(\d+)/ ? ('X#0?', sprintf "GTO %02d\n", $1) :
/iflt\s+(\d+)/ ? ('X<0?', sprintf "GTO %02d\n", $1) :
/ifge\s+(\d+)/ ? ('X>=0?', sprintf "GTO %02d\n", $1) :
/ifgt\s+(\d+)/ ? ('X>0?', sprintf "GTO %02d\n", $1) :
/ifle\s+(\d+)/ ? ('X<=0?', sprintf "GTO %02d\n", $1) :
/if_icmpeq\s+(\d+)/ ? ('X=Y?', sprintf "GTO %02d\n", $1) :
/if_icmpne\s+(\d+)/ ? ('X#Y?', sprintf "GTO %02d\n", $1) :
/if_icmplt\s+(\d+)/ ? ('X>Y?', sprintf "GTO %02d\n", $1) :
/if_icmpge\s+(\d+)/ ? ('X<=Y?', sprintf "GTO %02d\n", $1) :
/if_icmpgt\s+(\d+)/ ? ('X<Y?', sprintf "GTO %02d\n", $1) :
/if_icmple\s+(\d+)/ ? ('X>=Y?', sprintf "GTO %02d\n", $1) :
Labels are missing though. That's the output of the previous example:
; Compiled from "PrimeFactors.java"
; public class primeFactors.PrimeFactors extends java.lang.Object{
; public primeFactors.PrimeFactors();
; Code:
; 0: aload_0
; 1: invokespecial #1; //Method java/lang/Object."<init>":()V
RTN ; 4: return
; public static java.util.List generate(int);
; Code:
; 0: new #2; //class java/util/ArrayList
ENTER ; 3: dup
; 4: invokespecial #3; //Method java/util/ArrayList."<init>":()V
; 7: astore_1
2 ; 8: iconst_2
STO 02 ; 9: istore_2
RCL 00 ; 10: iload_0
1 ; 11: iconst_1
X>=Y? ; 12: if_icmple 45
GTO 45
RCL 00 ; 15: iload_0
RCL 02 ; 16: iload_2
MOD ; 17: irem
X#0? ; 18: ifne 39
GTO 39
; 21: aload_1
RCL 02 ; 22: iload_2
; 23: invokestatic #4; //Method java/lang/Integer.valueOf:(I)Ljava/lang/Integer;
; 26: invokeinterface #5, 2; //InterfaceMethod java/util/List.add:(Ljava/lang/Object;)Z
; 31: pop
RCL 00 ; 32: iload_0
RCL 02 ; 33: iload_2
/ ; 34: idiv
STO 00 ; 35: istore_0
GTO 15 ; 36: goto 15
1 ; 39: iinc 2, 1
STO+ 02
GTO 10 ; 42: goto 10
; 45: aload_1
RTN ; 46: areturn
Far from perfect but maybe a good starting point.
Kind regards
