HP Forum Archive 20
Evolution of the 30B
Message #1 Posted by Keith Midson on 19 June 2011, 8:34 p.m.
Hello all, with all this talk of the WP34S, I thought i'd post a pic of the evolution of the 30B, which many use to drive the 34.
http://www.flickr.com/photos/60529780@N02/5850241487/in/photostream
This appears in my prototype and rarities set:
http://www.flickr.com/photos/60529780@N02/sets/72157626354800664/with/5850241487/
and HP collection set:
http://www.flickr.com/photos/60529780@N02/sets/72157626354812528/
I've posted these links before, but there are a few new pics in there now.
Enjoy! Keith
Re: Evolution of the 30B
Message #2 Posted by Eric Rechlin on 19 June 2011, 8:48 p.m.,
in response to message #1 by Keith Midson
The one labeled as a "later prototype" was actually the initial production version. It was mixed in with the later production version for quite a while, so there's no serial number cutoff for it (I came across quite a few examples of sequential serial numbers where one had the old labels and one had the new labels).
Message #3 Posted by Keith Midson on 19 June 2011, 9:13 p.m.,
in response to message #2 by Eric Rechlin
Hi Eric,
The clear case has the following label on the back:
Ver 8 18 2009
The other version has:
Ver 10 13 2009
So i'd say the silver version is slightly newer. This is also what I was told when I received them.
Cheers, Keith
Message #4 Posted by Eric Rechlin on 19 June 2011, 9:51 p.m.,
in response to message #3 by Keith Midson
Yes, and that doesn't contradict anything I said. The clear one is a prototype; the other appear to be production models.
Eric
Message #5 Posted by Keith Midson on 19 June 2011, 11:58 p.m.,
in response to message #4 by Eric Rechlin
This might clear it up:
http://www.flickr.com/photos/60529780@N02/5851164945/in/photostream
These units were used in the beta testing of the firmware. Cheers, Keith
Edited: 20 June 2011, 12:00 a.m.
Message #6 Posted by Keith Midson on 20 June 2011, 12:02 a.m.,
Also - the 'PGRM' button differs between the final production version and the middle prototype (PGRM vs Pgrm). It is labelled "keypad" in the clear cased version.
Edited: 20 June 2011, 12:18 a.m.
Message #7 Posted by Eric Rechlin on 20 June 2011, 12:26 a.m.,
in response to message #6 by Keith Midson
I think production ones showed both PRGM and Prgm also. I believe it was changed the same time the % Calc, BEG, END, 1/x, xP/YR, nPr, and nCr keys changed. I can't verify because I don't have both in front of me now, but I do know that I have both examples.
Eric
Message #8 Posted by Marcus von Cube, Germany on 20 June 2011, 2:27 a.m.,
If you open a 30b (I did it to add the crystal oscillator) you can "clearly" see that the front shell is always made of clear plastic. The silver is just a coating. The window for the LCD is simply an uncoated area of the shell. That's a nice production trick :-).
Message #9 Posted by Keith Midson on 20 June 2011, 2:59 a.m.,
in response to message #8 by Marcus von Cube, Germany
I'm not sure how much clearer I can make this - both versions were not production models. These were used in testing of the firmware between August and November 2009 well before they were available to consumers. I don't know how much technical difference there is between the second prototype and the final production version, but the prototype was not a production version that could be purchased anywhere - it was used in the fine tuning of the firmware for the final model.
Maybe I am misunderstanding the comments, but the only production model is the third calculator, which I purchased only a few weeks ago for comparison purposes (to complement the prototypes in the collection).
Message #10 Posted by Andrés C. Rodríguez (Argentina) on 20 June 2011, 9:35 a.m.,
That opens another possible way for 34S "keypanel" labeling... At least, it would be protected from scratches, wear, finger oils...
Do you think it's possible to remove the silver coating in a reasonable way? Or to ask HP to sell uncoated topcases as spare parts? I know they won't take small orders, but...
Keys would still be a challenge.
(edited just to remove a couple of typos)
Edited: 20 June 2011, 2:56 p.m. after one or more responses were posted
Message #11 Posted by Tim Wessman on 20 June 2011, 1:07 p.m.,
in response to message #10 by Andrés C. Rodríguez (Argentina)
No, the silver coating is sandwiched between plastic. It isn't on the surface.
TW
Message #12 Posted by Marcus von Cube, Germany on 20 June 2011, 2:45 p.m.,
in response to message #11 by Tim Wessman
Tim, if I understand you correctly, the silver layer is a thin foil which is put into the mold before the clear plastic is shot in. It should be possible to replace this foil by a different design during the production process without too much effort.
