Trying to understand Spice ROM/RAM Layout Message #1 Posted by Michael de Estrada on 17 June 2011, 9:55 a.m.
I have been restoring the HP Spice series calcs for some time now, and have come to the realization that I do not understand how the RAM/ROM is arranged. All Spice series calcs have one large IC chip and 1 or 2 or 3 small ICs. Yesterday, I was working on my HP-34C with non-soldered keyboard and accidentally knocked 2 of the 3 small ICs out of their holder. I took a 50-50 guess as to which one went where. When I reassembled the calc, it seemed to work perfectly in both run and program mode, and passed the self-test, so I assumed that I had guessed correctly. However, when I switched it off and then on, I got a Pr Error and memory had been erased. At first I thought is was a bad connection problem, but when that did not work, I switched the two ICs, and to my amazement the calc worked properly and the Pr Error problem disappeared. In the past when I got the small ICs out of order the calc did not work properly and gave the self-test Error 9, indicating a self-test failure. So, what exacly are the ICs? Is the large IC a ROM and the small IC(s) just RAM? If so, how are the small ICs arranged? I'm sure someone out there knows all this.
TIA - Michael
