Re: 82161A Tape Drive - O-Ring Question Message #4 Posted by Eric Smith on 18 June 2011, 4:33 a.m., in response to message #1 by 聲gel Martin
I doubt that replacement parts are available, but just FYI:
The retainer washer is HP P/N 3050-1042, made of mylar.
The thrust washers that are paired below the retainer washer are HP P/N 3050-1065, claimed to be made of "nyletron". I suspect that it is actually Nylatron GS, which is nylon filled with molybdenum disulfide (MoS2), typically used for strength, rigidity, wear resistance, and low coefficient of thermal expansion.
Presumably any other plastic washer of approximately the same dimensions should work, though perhaps not as well or for as long a lifetime. Normal nylon has poor dimensional stability due to water absorption.
